    singcang's Avatar
    singcang is offline Upload and Share
    May 2009
    C:\WINDOWS\system32
    Total Audio Converter 3.0.1.57
    Total Audio Converter 3.0.1.57 | 7.79 Mb
    Ask yourself what is a perfect audio converter for you? Supporting all audio formats? To be handled via command line? The one with built-in audio player and CD ripper? And sure easy-to-use? We have just the one you can dream of - Total Audio Converter.
    Widest List Of Audio Formats Supported. Total Audio Converter supports more than 30 audio formats as source formats! You can convert files of almost any type with it. The target formats are WAV, MP3, OGG, WMA, APE, FLAC, MP4, AAC, MPC. It's not an mp3 converter
    or ogg converter, it's all formats converter (note the price!).
    Batch conversion. Either you have one file or a hundred of them it will take you seconds to set the conversion process.
    Command line. Command line is a great thing to run your converter from within other programs. All command line parameters are described so even a beginner will master them in no time.
    Rip CD. This option allows you to rip audio tracks from CD's and convert them to another format at the same time. Quite time saving!
    Built-in audio player. Total Audio Converter has built-in audio player. Now you can play your song before or after the conversion. Sometimes it's the best way to find the difference between formats.
    thay đổi nội dung bởi: singcang, 07-09-2009 lúc 07:58 PM
  1. [Mediafire] E.M. Total Video Converter 3.21 Build 090220 - chuyển đổi video, audio số 1 thế giới
    By kenzi_100c in forum Burning - Converter - Ripper
    Bài mới gởi: 18-03-2009, 08:41 PM
  2. [Mediafire] Total Audio Converter v3.0.1.42
    By rey in forum Burning - Converter - Ripper
    Bài mới gởi: 20-02-2009, 02:51 PM
  3. [Direct Link] Total Audio Converter 3.0
    By HDG in forum Burning - Converter - Ripper
    Bài mới gởi: 31-12-2008, 08:52 AM
  4. Trả lời: 0
    Bài mới gởi: 22-07-2008, 09:59 AM
    Bài mới gởi: 16-07-2008, 10:37 PM
