kết quả từ 1 tới 2 trên 2
    tnt1411's Avatar
    tnt1411 is offline (¯`•¸•´¯) Luv U 4ever (¯`•¸•´¯)
    Oct 2008
    Huế - Đà Nẵng - Sài Gòn
    Power Screen Capture v7.1.0.318 Regged-CzW
    With Power Screen Capture, you can capture screen from your desktop with high quality. Besides, it offers you the function of capturing video and image from other devices, DV and TV tuner. A list displays all the files captured by Power Screen Capture, and then you can view, copy, delete and rename these files freely and easily! Various settings let you set video compression codec, audio compression codec, output frame size and frame rate. You can also set properties of each capture device, preview and record real-time video, watch TV (TV Tuner is installed), add water mark or texts on video or image, etc.
    Chỉ có một điều tuyệt đối đó là mọi thứ đều tương đối…
  2. #2
    FBI-5's Avatar
    FBI-5 is offline Level 4
    Jan 2009
    chỉ up baì thôi mà ko giải thích bằng tiếng Việt thì dở quá .
  1. Power Screen Capture 7.1.0.243 Portable
    By strong29 in forum Portable
    Bài mới gởi: 19-07-2010, 10:23 AM
  2. Power Screen Capture 7.1.0.232 Portable
    Bài mới gởi: 01-07-2010, 01:12 PM
  3. Power Screen Capture 7.1.0.57
    By singcang in forum Graphics & Designs
    Bài mới gởi: 18-09-2009, 04:39 PM
  4. [MultiLink] Power Screen Capture 7.1.0.49
    By singcang in forum Desktop Enhancements
    Bài mới gởi: 09-08-2009, 12:59 PM
  5. [MultiLink] Power Screen Capture 7.1.0.2
    By HDG in forum Portable
    Bài mới gởi: 28-04-2009, 09:54 PM
