Portable Ultra ISO Premium 9.43 | 4 MB
UltraISO is a CD/DVD image file creating/editing/converting tool , it can directly edit the CD/DVD image file and extract files and folders from it, as well as directly make ISO files from your CD/DVD drive or hard disk. At the same time, you can maintain the ISO bootable information, thus creating your own bootable CDs and DVDs. You now have the power to make and edit your own ISO files, and then burn them to CD or DVD for your own needs.
1. Can directly edit the ISO image file.
2. Can directly extract files and folders from ISO image file
3. Can add / delete /create new directory /rename ISO file image content.
4. Can make ISO file from hard disk document.
5. Can create CD image from CD-ROM, maintain bootable information.
6. Can process the compact disc boot information, you can directly add/remove/extract boot image of the ISO image.
7. Supports nearly all known CD image file formats (.ISO, .BIN, .IMG, .CIF, .NRG, .BWI and so on) , and converts them to the standard ISO form image.
8. May directly set the file/folder to hidden attribute
9. Supports ISO 9660 Level1/2/3 and Joliet extension
10. Automatically optimizes the ISO image file structure, saves the CD space.
11. Supports the shell document type integration, Open Image files through double clicking them or the Right Click menu of the mouse with the open dialog.
12. The double window user interface is extremely convenient to use.
13. There are rich add-on tools, you can create ALL in 1 bootable compact discs, CD image file management, even the virtual CD/DVD drive, those functions are really powerful.
- Portable Netscape Navigator 9.0.0.6 - Trình duyệt một thời vang bóng trở lại
- [D-Link] Portable Batch Picture Resizer v.2.3 - thay đổi kích thước ảnh
- Portable DVDFab Platinum 6.0.7.0
- Portable OJOsoft Total Video Converter 2.7.1.1008
- [D-Link] Portable Spyware Terminator 2.3.0.481 - loại bỏ spyware khá hiệu quả
- Portable Orbit Downloader 2.8.9 Multilanguage
- Portable WinSnap 3.1.0
- Portable VSO Image Resizer 3.0.1.55
- Portable iTunes 7.6.2.9 + Quicktime 7.4.5 Pro
- STDU Explorer 1.0.414 Portable
