Nikon Camera Control Pro
- This software is designed to remotely manage the settings of most digital SLR cameras Nikon. The camera can be connected to a computer via USB cable to a wired or wireless network using a wireless transmitter. At the same time providing support for advanced camera capabilities, such as LiveView, Picture Control System and Viewer, which provides an opportunity to preview and select images before transferring them to your computer. The list of supported cameras and functionality is presented below. This software allows you to manage most of the camera remotely - from a computer.
Key Features:
Remote control most of digital SLR camera from the computer (including the management regime of exposure, shutter speed and aperture).
Office of besprovovodnoy or wired network using a wireless transmitter.
Direct transfer of images from the camera to the computer and managing all processes from capture to save the images.
Enhanced Viewer feature provides a display of small images of photos stored on your computer.
Images in a camera buffer can be confirmed or deleted before the transfer to your computer using the screen preview or operations with reduced images.
Mode LiveView (Hand-held and Tripod), in which the sensor camera provides a preview in real time through the lens. Supports LiveView mode provides simultaneous adjustment of focus and / or shutter, together with confirmation of image capture on a computer screen. In Tripod mode, is supported by the opportunity to remotely select the desired point autofocus.
Maintain a system of management regimes images, allows you to choose and adjust the picture settings on your computer, create custom curves (data about the changing tone) and save them on camera.
http://rapidshare.com/files/263386579/Nikon.Camera.Control.Pro.v2.5.0.rar
[PASS][/PASS]
