Corel DESIGNER Technical Suite X4 2010 | 381.62 MB
Corel DESIGNER Technical Suite X4 is the trusted choice for businesses that need to effectively communicate the strengths of their products and services through clear, informative technical illustrations or diagrams.
From operation guides and parts catalogs, to schematics, wiring diagrams, assembly instructions,
maintenance manuals and architectural presentations, this complete suite allows organizations of any size to create powerful technical graphics—fast!
What's Included:
* Corel DESIGNER X4
* Corel PHOTO-PAINT® X4
* Corel® PowerTRACE™ X4
* Corel CAPTURE™ X4
* Right Hemisphere® Deep Exploration™ 5.7 CSE
* Printed User Guide
What's Included
* Corel DESIGNER® X4 - a precision vector drawing and layout application for technical illustrators
* Corel PHOTO-PAINT® X4 - an easy-to-use, professional image-editing program
* Corel® PowerTRACE™ X4 - an accurate bitmap-to-vector image tracing application
* Corel CAPTURE™ X4 - a one-click screen capture utility
* Right Hemisphere® Deep Exploration™ 5.7 CSE - a powerful application that transforms 3D designs into accurate 2D illustrations
* User Guides - for Corel DESIGNER X4 and Corel PHOTO-PAINT® X4 (on CD and as a printed manual in the box)
* 4,000 standard drawing components, categorized in over 75 symbol libraries
* Tutorials - 6 new Corel DESIGNER tutorials, 5 new Corel PHOTO-PAINT tutorials, tips & tricks
Access Technical Design Assets
New! 3D CAD Import
Open and work with 3D designs (including AutoCAD® 3D DWG™ and DXF™, 3DS, VRML, U3D, SketchUp™ files
and others) without needing a CAD license or having to navigate a complicated interface.
Optional: Additional native 3D CAD File Format Support
Upgrade to Deep Exploration CCE for direct access to over 80 3D file formats from major CAD systems such
as CATIA®, Inventor®, Pro/ENGINEER®, SolidWorks®, Unigraphics® NX and more. Find out more about this
add-on tool.
Enhanced! AutoCAD DWG/DXF Support Work with 2D CAD files from your suppliers or customers. Receive support for AutoCAD 2008 and versions
dating back to 2.5, plus enjoy enhanced object, layer and hatch fills support.
New and enhanced! File Format Support
Easily collaborate with colleagues and clients thanks to seamless compatibility with commonly used file
formats, including new support for Microsoft® Visio 2007, PDF 1.7 and PDF/A, Microsoft® Word 2007,
Microsoft® Publisher® and JPEG 2000.
Computer Graphics Metafile (CGM) Support
Import and export to files of CGM Version 4 profiles, such as ActiveCGM, WebCGM, and ATA GREXCHANGE 2.4 and 2.6.
New! Corel® PowerTRACE™ X4 Quickly unlock and repurpose data in legacy blueprints.
New! Welcome Screen
Quickly access recently used documents, templates, learning tools and inspiring illustration work.
New! Windows Vista® Integration
Easily organize projects and search for files within a modern, more intuitive interface, and benefit from
high-quality thumbnail previews that improve productivity and reduce searching time.
New! CorelDRAW® ConceptShare™
Share work and collaborate with colleagues and/or clients in real time.
Streamline Technical Illustrations
New! Object Coordinate Docker
Draw, size and rotate shapes and lines with enhanced precision and live screen preview.
Enhanced! Dimension Tools Create custom dimensions and dimension styles with advanced control for clearly readable illustrations.
Enhanced! Arrowheads
Add precise arrowheads to connectors, callouts, dimension lines and any curve.Projected Drawing Modes
Dramatically increase productivity by actively drawing on the projected plane, removing the need to draw the
object first and then project or squeeze it in additional steps.
3D CAD
Corel DESIGNER Technical Suite X4 includes Right Hemisphere® Deep Exploration™ 5.7 CSE, a powerful
application that transforms 3D CAD models into accurate 2D graphics.
To double your 3D CAD editing abilities and benefit from increased file format support, upgrade to Deep Exploration™ 5.7 CCE. See below for more information.
With Deep Exploration™ 5.7 CSE (included with Corel DESIGNER Technical Suite), you can:
* access 3D designs from AutoCAD® DWG™ and DXF™, 3DS, VRML, U3D, SketchUp™ and other formats
* modify 3D models and views to accommodate the needs of a technical illustration (e.g., by applying cross
sections and exploding models to create disassembly views)
* quickly transform 3D CAD models into accurate 2D vector illustrations and insert directly into Corel
DESIGNER X4
* create renderings from 3D designs to output directly to Corel PHOTO-PAINT® for professional retouching and integration in technical documents and presentations
With Deep Exploration™ 5.7 CCE* (upgrade option) you receive:
* additional native 3D CAD file format support - get support for over 80 3D CAD file formats, including
* 3D PDF publishing abilities
* more 3D CAD tools to optimize 3D files for display and manipulation, such as Polygon reduction tools, small parts removal and more
System Requirements
* Windows Vista Home Basic, Home Premium, Ultimate, Enterprise, and Business (32 Bit and 64 Bit) or
Windows XP Home, Professional, Media Edition, 64-Bit or Tablet PC Edition (with latest Service Pack and
Critical Updates)
* Pentium III, 800 MHz or AMD Athlon XP
* 512 MB RAM
* Mouse or tablet
* 1024 x 768 screen resolution (768 x 1024 on a Tablet PC)
* CD-ROM drive
* 1.2 GB hard disk space for the default installation
* Microsoft Internet Explorer 7 or higher
installation instruction
simple
double click setup.exe
use keygen to register
Download (Hotfile)
http://hotfile.com/dl/36908030/f9f72a5/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part1.rar.html
http://hotfile.com/dl/36908059/5ca565d/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part2.rar.html
http://hotfile.com/dl/36908060/32e8fba/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part3.rar.html
http://hotfile.com/dl/36908065/ad3a33f/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part4.rar.html
Mirror:
Download (Uploading)
http://uploading.com/files/832b2afc/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part1.rar/
http://uploading.com/files/a7acadbm/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part2.rar/
http://uploading.com/files/4c4a4fbb/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part3.rar/
http://uploading.com/files/ec77f927/Corel.Designer.Technical.Suite.X4.v14.1.0.195-HeartBug.part4.rar/
