Autodesk 3ds Max 2011 Autodesk 3ds Max Design 2011 32-bit | 2.3 GB
3ds Max 2011 - new version of the popular program for 3D-modeling, animation and rendering. 3ds Max includes a high-performance tools needed to create spectacular movies and television screen savers, modern computer games and presentation materials. The program allows you to quickly create realistic characters, seamless CG effects, captivating computer games, as well as high-quality films and television programs. Advanced tool kits let you create 3D environments to suit your needs, easy to manage complex scenes, and take advantage of improved interoperability and integration support.
Features 3ds Max 2011:
"Data and Scene Management
"Creation of parametric and organic shapes and objects
"Polygon modeling and texturing
"Tools polygonal modeling
"Spline-surface and anti-aliasing polygons
"Tools optimization
"Imposing and texture editing
"Modeling splines
"Keyframe animation
"Animation Controllers
"Limited animation
"Animation of scripts and expressions
"Animation of modifiers
"Character Animation
"Animation biped characters
"Sets Animation resources
"Non-linear animation mixer movements
"Storage options
"Capturing motion
"Modeling and texturing
"The dynamics of hard and soft bodies (Reactor)
"Visual effects on clothing
"Viewing, editing and mixing caches
"Extensible Integrated Particle
"Combined Rendering
"Managing rendering and creating special effects
"Modeling of Materials
"Managing rendering
"Supported Formats 3DS, AI, DDF, DEM, DWG, DXF, OBJ, PRJ, SHP, STL, TRC, VW, WRL, WRZ, and many others
"Using plug-ins
Instructions for installing 3ds Max 11, ISO-image:
1). Unpack the archive and mount the disk image using DAEMON Tools or Alcohol 120%
2). Run the installer 3ds Max 2011
3). When asked to enter a serial number, type something like 666-69696969
4). In the \ \ \ \ "Product Key \ \ \ \" type 128C1 and install the program
5). After installation, disconnect from the Internet
6). Start 3ds Max 2011 and crack from folder Crack in a disk image
7). Click Activate in the window 3ds Max 2011
8). In keygens click Mem patch
9). Copy from windows activation request code in the top field keygens and click Generate, copy the activation code in the window of activation
10). Enjoy!
PS: Windows Vista users and Windows 7 should run as administrator
Developer: Autodesk Software
Enabling | reg code: Present
Interface Language: English
Filesize: 1.07 / 1.10 GB
OS: Microsoft Windows XP, Vista and Seven
Download (Hotfile)
http://hotfile.com/dl/36705336/e1e9497/Autodesk.3ds.Max.(Design.)2011rar.part01.rar.html
http://hotfile.com/dl/36705337/e27f4e8/Autodesk.3ds.Max.(Design.)2011rar.part02.rar.html
http://hotfile.com/dl/36705340/0d4fa82/Autodesk.3ds.Max.(Design.)2011rar.part03.rar.html
http://hotfile.com/dl/36705333/74617ca/Autodesk.3ds.Max.(Design.)2011rar.part04.rar.html
http://hotfile.com/dl/36705335/81e503b/Autodesk.3ds.Max.(Design.)2011rar.part05.rar.html
http://hotfile.com/dl/36705332/6545d36/Autodesk.3ds.Max.(Design.)2011rar.part06.rar.html
http://hotfile.com/dl/36705334/10696fd/Autodesk.3ds.Max.(Design.)2011rar.part07.rar.html
http://hotfile.com/dl/36705338/f868471/Autodesk.3ds.Max.(Design.)2011rar.part08.rar.html
http://hotfile.com/dl/36705331/fe39f26/Autodesk.3ds.Max.(Design.)2011rar.part09.rar.html
http://hotfile.com/dl/36705339/f1ecfcc/Autodesk.3ds.Max.(Design.)2011rar.part10.rar.html
http://hotfile.com/dl/36705494/1fa8ee1/Autodesk.3ds.Max.(Design.)2011rar.part11.rar.html
http://hotfile.com/dl/36705504/a81ce7a/Autodesk.3ds.Max.(Design.)2011rar.part12.rar.html
http://hotfile.com/dl/36705505/d0881af/Autodesk.3ds.Max.(Design.)2011rar.part13.rar.html
http://hotfile.com/dl/36705513/5516b7a/Autodesk.3ds.Max.(Design.)2011rar.part14.rar.html
http://hotfile.com/dl/36705515/3c075cb/Autodesk.3ds.Max.(Design.)2011rar.part15.rar.html
http://hotfile.com/dl/36705522/e680011/Autodesk.3ds.Max.(Design.)2011rar.part16.rar.html
Mirror:
Download (Uploading)
http://uploading.com/files/653bafcc/Autodesk.3ds.Max.%28Design.%292011rar.part01.rar/
http://uploading.com/files/4ffbmfm6/Autodesk.3ds.Max.%28Design.%292011rar.part02.rar/
http://uploading.com/files/4m13e7fc/Autodesk.3ds.Max.%28Design.%292011rar.part03.rar/
http://uploading.com/files/9m48aead/Autodesk.3ds.Max.%28Design.%292011rar.part04.rar/
http://uploading.com/files/dc689b8e/Autodesk.3ds.Max.%28Design.%292011rar.part05.rar/
http://uploading.com/files/a234e997/Autodesk.3ds.Max.%28Design.%292011rar.part06.rar/
http://uploading.com/files/85493ee3/Autodesk.3ds.Max.%28Design.%292011rar.part07.rar/
http://uploading.com/files/e8mdc2b6/Autodesk.3ds.Max.%28Design.%292011rar.part08.rar/
http://uploading.com/files/f4627797/Autodesk.3ds.Max.%28Design.%292011rar.part09.rar/
http://uploading.com/files/memeaf5f/Autodesk.3ds.Max.%28Design.%292011rar.part10.rar/
http://uploading.com/files/de8e89cb/Autodesk.3ds.Max.%28Design.%292011rar.part11.rar/
http://uploading.com/files/m86b59f8/Autodesk.3ds.Max.%28Design.%292011rar.part12.rar/
http://uploading.com/files/c79e6645/Autodesk.3ds.Max.%28Design.%292011rar.part13.rar/
http://uploading.com/files/e7b8c266/Autodesk.3ds.Max.%28Design.%292011rar.part14.rar/
http://uploading.com/files/a345bm62/Autodesk.3ds.Max.%28Design.%292011rar.part15.rar/
http://uploading.com/files/2mea9bad/Autodesk.3ds.Max.%28Design.%292011rar.part16.rar/
All links are interchangeable
