MAGIX Audio Cleaning Lab 15 Deluxe 10.0.2.0
Rapidshare Link | 109.2 MB
MAGIX Audio Cleaning Lab 15 deluxe is your personal audio toolbox, offering unlimited possibilities to edit all kinds of audio material! MAGIX Audio Cleaning Lab 15 deluxe makes producing perfect audio recordings easy! Simply click "Record" and the integrated recorder records everything that you can hear via the sound card. Of course, non copy-protected audio CDs and MP3 files can be imported without any problems. Complicated recording settings are finally a thing of the past. Individual pieces of music are automatically detected and separated from each other or saved already during the recording process. Even the volume can be adjusted automatically to the optimum level. And if you want to record a special radio program, then just use the practical timer: Enter the date and time, and your PC will start the recording automatically.
Cut, edit, add effects, etc. – everything is so easy that no time is required to learn. Even high-end audio editing is possible! Even more specialized tasks can be carried out with ease by this advanced program: Edit the information for individual MP3s and complete it automatically. The volume of background music can be reduced for spoken recordings - ideal for podcasts. Discover audio editing at the highest level – and with the easiest handling.
Experience a completely new kind of sound – at a single click if you want:Clipping, fixling vinyl, audio disturbances, noise, popping, and humming can be filtered out of every recording. You can also remedy volume fluctuations, recover lost overtones, correct the tempo, and optimize the frequency settings. Fine tuning is also possible with the equalizer. There are also numerous effects for producing a perfect, neutral stereo image: crystal clear, warm, and flawless! MAGIX Audio Cleaning Lab 15 deluxe helps you achieve the best results possible!
To enjoy your complete music collection consisting of LPs, cassettes, and other audio media digitally, simply burn your recordings onto CD & DVD with a single click. If you like it compact, MAGIX Audio Cleaning Lab 15 deluxe offers you an especially practical solution: Up to 100 hours of music can be burned to DVD in MP3 format! With the help of the export function, you can experience your music collection on the go – on your cell phone or MP3 player!
Advanced functions:
» Record web radio broadcasts
» Automatic recognition of song start
» Find the optimum volume for every music track automatically
» High-end, detailed audio editing with MAGIX Music Editor 2.0
» VoiceOver function: Turns down background music during voice-overs – perfect for podcasts
http://rapidshare.com/files/244863680/MAGIX.AUDIO.CLEANING.LAB.DELUXE.v15.part1.rar
http://rapidshare.com/files/244863505/MAGIX.AUDIO.CLEANING.LAB.DELUXE.v15.part2.rar
[PASS][/PASS]
