ImTOO Audio Encoder 6.1.2 Build 0719 Portable | 26.67 MB
The definitive audio conversion and extraction specialist. ImTOO Audio Encoder is all you will ever need to convert between most audio formats as well as extract audio from most video files. Among the many different media formats supported by ImTOO AudioEncoder include videos (such as AVI, MPEG, WMV, MP4, FLV, MKV), high-definition (HD) videos (such as AVCHD, H.264/MPEG-4 AVC), and audio (such as MP3, WAV, FLAC, WMA, AAC, OGG, APE).
Features
· Convert between most audio formats including MP3, WMA, WAV, AAC, FLAC, OGG, APE
· Rip audio from video and HD-video files of various formats including AVI, MPEG, WMV, MP4, FLV, MKV, H.264/MPEG-4 AVC, AVCHD
· Makes full use of your multi-core’s processing speed during conversion with multi-core CPU processing and multithreading supported
· Convert several files in one go with ImTOO Audio Encoder’s batch conversion functionality
· Simultaneously convert a file to several formats of your choice
· Convert a segment from an audio file or extract an audio segment from a video file to different formats
· Split a larger file into several, split either by size or time length
· Convert your file to the exact size using ImTOO Audio Encoder’s handy Bitrate Calculator tool
· Convert your file to meet specific needs by setting various output parameters accordingly
· Play different format files with ImTOO Audio Encoder’s built-in media player
· Run audio conversions in the background for reduced CPU usage and increased efficiency
· Set a “Post-Task Action” (exit application, hibernate, stand by, shut down system, no action) and the selected action will be performed automatically after all tasks are complete
· ImTOO Audio Encoder’s interface is available in English, French, German, Japanese, Spanish, Simplified and Traditional Chinese
http://hotfile.com/dl/58553887/789a98c/VIP_ImTOO.Audio.Encoder.6.1.2.Build.0719.Portable.rar.html
