Geometric Technologies eDrawings 2011 Pro 32bit & 64bit | 420.7 Mb
Fast, reliable, and convenient, eDrawings files supply accurate representations of 3D models and 2D drawings created with the most widely used CAD systems in the market.
About Geometric
Geometric is a specialist in the domain of engineering solutions, services and technologies. Its portfolio of Global Engineering services and Digital Technology solutions for Product Lifecycle Management (PLM) enables companies to formulate, implement, and execute global engineering and manufacturing strategies aimed at achieving greater efficiencies in the product realization lifecycle.
Headquartered in Mumbai, India, Geometric was incorporated in 1994 and is listed on the Bombay and National Stock Exchanges. The company recorded consolidated revenues of Rupees 5.12 billion (US Dollars 108.1 million) for the year ended March 2010. It employs close to 3000 people across 11 global delivery locations in the US, France, Romania, India, and China. Geometric is assessed at SEI CMMI Level 5 for its software services and ISO 9001:2000 certified for engineering operations.
About eDrawings
Features & Benefits
The following innovative features give eDrawings the capabilities that you need to overcome common barriers to effective design communication
- Ultra Compact Files
eDrawings are substantially smaller in size compared to the original CAD files, making them easy to send by email, even over slow connections. With eDrawings, it's finally practical to send design data via email.
- Built-in Viewer
eDrawings offer a complete, self-contained communication tool since no other viewing software is needed. In addition, eDrawings viewer can view native SolidWorks parts, assemblies and drawings, and also AutoCAD files.
- Layouts
Open individual views in a drawing and arrange them in any way you desire, regardless of how the views were arranged in the original drawing. eDrawings layouts also automatically align the views intelligently and enable the eDrawings recipient to print and export any subset of a drawing.
- 3D Pointer
Easily identify and match geometry in multiple views using the 3D Pointer.
- Animation
Demonstrate how drawing views relate to each other. With the click of a button eDrawings animates all the views contained in your drawing. Try out this feature yourself and see why everyone is so excited about eDrawings!
- Save as STL
eDrawings can be optionally exported by the eDrawings Viewer as STL files.
- Batch Publish
Convert multiple CAD files to eDrawings.
- Markups
Add markup elements, such as geometric elements, clouds, text, or dimensions to the comment using the markup tools.
- Data Protection
You can disable measurement and STL export of eDrawings files to protect sensitive data
- Measurement
Use the Measure tool to measure exact dimensions in part, assembly, and drawing files. For isometric type drawing views, the projected length is displayed instead of the true length.
- Dynamic Cross-section
View cross sections of part and assembly files by creating a variety of cross section planes.
- Explode Views
You can display exploded view information in assembly documents that you open in the eDrawings Viewer. When you publish eDrawings assembly files(.easm) that have exploded view information, the explode information is saved with the eDrawing file automatically.
- Move Components
The Move Component feature lets you move individual components in an assembly file, or in a drawing file of an assembly. You can also move entire subassemblies.
- Mass Properties
Query Mass, Volume, Density (parts only), and Surface area of the model.
eDrawings Publishers are available for the following CAD platforms
- eDrawings for Pro/ ENGINEER (Pro/ENGINEER 2001 & Pro/ENGINEER WildFire 1.0, 2.0, 3.0, 4.0 & WildFire 5.0)
- eDrawings for CATIA V5 Publisher (CATIA V5 R16, R17, R18, R19 & CATIA V5 R20)
- eDrawings for Unigraphics/NX (NX5, NX6, NX7 & NX7.5)
- eDrawings for Autodesk Inventor (Autodesk Inventor 8, 9, 10, 11, 2008, 2009, 2010 & Autodesk Inventor 2011)
- eDrawings for Solid Edge (Solid Edge V19, V20, ST, ST2 & Solid Edge ST3)
Homepage - http://edrawings.geometricglobal.com/
