PIXELPLAN Flow Architect Studio 3D is a software package that enables a simple and easy way to create interactive 3D visualization - virtual walks. Created visualizations are like a computer program, located in one file and are suitable for further distribution and publication on the website.
In PIXELPLAN Flow Architect Studio 3D
* You can quickly and easily create a visualization of any object
* You have to keep the facilities built preview (WYSIWYG)
* Have the ability to build any walls and the creation of custom objects
* And any of their deployment
* In a natural way you arrange the lighting
* And create animations of selected geometric objects
* You can use libraries of models, materials and textures
* In a simple way with your project, you can generate the final visualization
* You can import new models for libraries
* And build from scratch your own library
Visualization created using PIXELPLAN Flow Architect Studio 3D
* Is a computer program allows you to freely walk
* Uses the latest 3D technology
* Has dynamic lighting
* And dynamic shadows
Homepage - http://www.pixelplan.pl/index.php?pid=oferta
Download From HotFile
http://hotfile.com/dl/98648844/70688...table.rar.html
Download From FileServe
http://www.fileserve.com/file/UAD8v8e
Download From FileSonic
http://www.filesonic.com/file/62427741/Flow.Architect.Studio.3D.v1.3.9.Bilingual.Portable .rar
- VueScan Pro 8.6.17 Portable
- Speed Video Converter 4.4.39 Portable
- SUPERAntiSpyware Professional 4.40.1002 Final Portable
- [MF] Portable Winamp 5.531 build 1938 Pro - bản Portable của phần mềm nghe nhạc hay nhất thế giới
- PowerArchiver 11.60.15 RC3 Portable
- CoffeeCup GIF Animator 7.6 Portable
- Portable WinRAR 3.80 Beta 4
- Software » Portable → AudioGrail 6.18.1.168 Portable
- Portable O&O Defrag 11.0 Build 3265 Professional Edition
- OpoSoft Video Editor v6.0 Portable
