kết quả từ 1 tới 6 trên 6
    WoWPoison's Avatar
    WoWPoison is offline Administrator
    Apr 2008
    [Dlink] Sony Sound Forge 9.0e Build 441 : Công cụ chỉnh sửa Multimedia chuyên nghiệp
    Precision, Stability, Ease, and Speed
    The Sound Forge 9 professional digital audio production suite includes everything you need to quickly get from raw audio to finished master. Use this suite to create and edit stereo and multichannel audio files with speed and precision. Efficiently analyze, record and edit audio, digitize and restore old recordings, model acoustic environments, design sound for multimedia, and master replication-ready CDs.
    Includes Tools for Sound Design and Mastering
    In addition to Sound Forge 9 software, this comprehensive audio production suite includes CD Architect 5 software for designing, mastering and burning Red Book audio CDs, Noise Reduction 2 plug-ins to fix common audio problems such as tape hiss, camera hum, clicks, and pops, and the Mastering Effects Bundle powered by iZotope™, a collection of four professional audio plug-ins.
    Stereo and Multichannel Recording
    Sound Forge 9 software has a complete set of tools for recording audio. Record straight into your sound card or use the Record Timer to begin and end a session at a specific time and date. Alternatively, you can start recording when a certain audio threshold is reached with Threshold Record Triggering. You can also now record and edit multichannel audio files as easily as stereo files. More About Recording and Playback
    Precise Audio Editing
    Edit stereo and native multichannel audio files down to the sample level in real time. Use familiar Windows commands to cut, copy, paste, mix, and crossfade audio. Drag and drop to edit between channels, and work on one file while processing others in the background. More About Editing and Workflow
    Pristine Sound Quality
    Sound Forge software supports full resolution 24-bit and 32-bit/64-bit float 192 kHz files for the ultimate in audio fidelity. Capture the subtle overtones and nuances of instruments, vocals, and effect changes. More General Features
    Powerful Effects Processing
    Apply over 40 professional studio effects and processes including Normalize, EQ, Delay, Chorus, Volume, Dynamics, Noise Gate, Pitch Shift, Flange, and Vibrato. Chain multiple effects together and apply them to selections or entire files using the Plug-in Chainer. Sound Forge 9 software also supports DirectX and VST effects, including parameter automation, to expand the number of effects you can apply to audio and increase your mastering flexibility. More About Tools and Effects
    Audio-for-Video
    Sound Forge 9 software supports multiple video formats including AVI, WMV, and MPEG-1 and MPEG-2. Synchronize audio and video frame by frame. Import Flash (SWF) files* to visually synchronize your audio to your project. Sound Forge 9 software includes MPEG-2 templates for writing HDV-compliant files at both 720p and 1080i resolutions. Also included are templates for encoding WMV 720p and 1080p.
    *ActionScripting, motion video, and audio not supported
    [HIDE]
    http://tinyurl.com/TuoitreNangdong-Ne-Sony-Sound9e441
    [/HIDE]
    [HIDE]
    http://tinyurl.com/TuoitreNangdong-Ne-Sony-Sound9e441ke-y
    Pass : www.TuoitreNangdong.Net
    [/HIDE]
    thay đổi nội dung bởi: ColonelRVH, 04-08-2008 lúc 07:38 PM
  2. #2
    minhcuchcm's Avatar
    minhcuchcm is offline Level 3
    Jul 2008
    Chào bạn. Key đang dùng chỉ là bản 9.c, đâu phải 9.e?.
  3. Những thành viên đã Thanks minhcuchcm:
  4. #3
    WoWPoison's Avatar
    Apr 2008
    Trích Nguyên văn bởi minhcuchcm View Post
    Đúng rồi bạn ạ, nhưng mình đã cài và key này vẫn dùng dc cho bản 9.e.
  5. Những thành viên đã Thanks WoWPoison:
  6. #4
    hoanghiep527's Avatar
    hoanghiep527 is offline Level 1
    Jun 2008
    ban ui key bao loi khong download duoc
  7. #5
    markhieu's Avatar
    markhieu is offline SMOD
    May 2008
    Tp Rạch Giá thân yêu
  8. The Following 5 Users Say Thank You to markhieu For This Useful Post:
  9. #6
    thangbom12's Avatar
    thangbom12 is offline Level 2
    Jul 2009
    help voi register
    tui làm tới bước thứ 6 tự nhiên điền Authentication code vô nó nói code bị xai
    ai biềt giúp giùm với cảm ơn
  1. Trả lời: 0
    Bài mới gởi: 23-11-2011, 02:11 PM
  2. Sony Sound Forge Pro 10.0 Build 368 + Sony.Products.Multikeygen.v1.6.Keygen
    By thanhbuata in forum Editor & Authoring Tools
    Bài mới gởi: 12-12-2009, 08:36 AM
  3. Trả lời: 0
    Bài mới gởi: 24-10-2009, 05:47 PM
  4. Trả lời: 1
    Bài mới gởi: 26-06-2009, 02:45 PM
    Bài mới gởi: 02-09-2008, 09:26 PM
