Smart DVD/CD Burner is an easy-to-use and effective DVD/CD burning software for Beginners and Professionals. With this burning program you can create high-quality CD (audio/data) and DVD discs, containing your music and files.
Full Drag and Drop support, Importing multi-session DVD/CDs, Burning Music CD directly from MP3/OGG/WMA/WAV files, On-the-fly recording, Erasing re-writable discs, Supporting majority of modern IDE/USB/SCSI/FireWire DVD/CD writers drive, Supporting buffer protection systems (BURN-Proof) and more are all included in the latest version of Smart DVD/CD Burner.
* Full Drag and Drop support
* Simple, easy-to-use and highly customizable interface
* Supports majority of modern IDE, USB, SCSI and FireWire CD/DVD writers
Pioneer, Sony, Ricoh, HP, Toshiba, Plextor, Lite-On, Mitsumi, HP, LG, Philips, TEAC, Toshiba, TDK, etc
* Supports all CD-R / CD-RW / DVD+R / DVD+RW / DVD-R / DVD-RW /
DVD-RAM discs
* Supports various MP3 / OGG / WMA / WAV audio files for burning music CD directly; no temporary files are required
* Produces excellent sound quality without distortion
* Supports Buffer Protection systems, like Burn Proof and others for error free recording
* Imports multi-session data DVD/CDs and merges new files with an existing session
* Testwrite function
* Quick and full erase rewritable discs
* Records DVD/CDs On-the-Fly; no disk space is required for temporary files
* Shows properties of your drive and disc
* Supports long file name and multilanguage (Joliet) file system
* Creates fully compatible ISO9660 Level 1, 2 and Joliet data DVD/CDs
* Built-in ASPI Layer for Windows NT, 2000 and XP
Home - http://www.burnersoft.com/dvdcd/features.htm
[HIDE][PHP]http://www.adrive.com/public/4c0a5c65acf69eee0b8fc06e5e11995a5b3756b9b0942679c3 a1200c37fcb5b6.html[/PHP][/HIDE]
