Advanced Sound Recorder, the powerful sound recorder and editor, makes a complete recording studio of your computer. With the recorder you can record voice from microphone, internet streaming audio, or music played by Winamp, Windows Media Player, Quick Time, Real Player, Flash, games, etc. Advanced Sound Recorder is able to automatically detect the recording formats your sound card supports and then set the application's parameters for the best possible performance. The recordings can be saved as .mp3, .wav, .wma, .vqf and .ogg files. What makes Advanced Sound Recorder more powerful is its editing feature. It can edit audio files as you desire by cutting, copying, pasting, trimming segments and employing various DSP effects. Another useful feature is recording schedule which enables automatic recording, that is, Advanced Sound Recorder starts and stops recording at any time you want.
Main Features:
sound recorder Powerful Recorder:
Advanced Sound Recorder can record any signal played through your sound card as Mp3, Wma, Vqf, Ogg or Wav files.
sound recorder CD Quality Recordings:
With its powerful sound engine Advanced Sound Recorder produces CD quality recordings.
mp3 sound recorder Audio File Editing:
Advanced Sound Recorder can edit audio files as you desire by cutting, copying, pasting, trimming segments and employing various DSP effects.
sound recorder Recording Schedule:
Advanced Sound Recorder can start and stop recording at any time you set.
audio streaming recorder Easy-to-use User-friendly Interface:
Advanced Sound Recorder is able to automatically detect the recording formats your sound card supports and then set the application's parameters for the best possible performance. The default parameters work in most cases, but you can change them easily to best suit your needs.
sound recorder software Record Volume Control Support:
Advanced Sound Recorder integrates complete set of record volume control for your convenience.
mp3 recorder Direct-To-Disk Long Time Recording Support:
Advanced Sound Recorder can record on the fly for as long as your like.
mp3 recorder Recording History Management:
Advanced Sound Recorder enables you to manage recording files conveniently.
mp3 recorder Voice Activation System:
Advanced Sound Recorder has a Voice Activation System with which you can choose to skip silent passages, or stop the recording after a certain amount of silence.
mp3 recorder Hotkey Support:
Advanced Sound Recorder supports hotkey setting (F8 by default).
[HIDE][PHP]http://www.adrive.com/public/2e2ad5e3b460aca0f7570d6729762fab2bb816322790dcaf7b 509fa6901206ec.html[/PHP][/HIDE]
- [Dlink]Crazy Talk 5 PRO-Tạo giọng nói vui nhộn
- Kong Audio ChineeErhu VSTi 1.4.4
- Movavi VideoSuite 8.0
- Elecard MPEG Player 5.3 Build 80624
- AIMP2 MegaPack 2.60.505.1
- DFX Audio Enhancer v9.203.0.0 x86/x64 All Products - Cho âm thanh hay vô đối
- [D-Link] Minilyrics v6.0 Final - Vừa nghe nhạc vừa xem lời hát
- DFX Audio Enhancer 9.107 All Version
- TouchCopy v4.39
- Any Video Converter Professional 3.1.6 ML
