FoxEasy NEW Products AIO 2008 Fox Audio CD Burner v7.4.0.10
Fox Audio Recorder v7.4.0.10
Fox Video Capture v6.2.0.238
Fox Flash Decompiler v3.0.0.1
Fox® DVD Ripper® Pro v8.0.8.10
Fox Audio Converter v7.4.0.10
Fox Audio CD Burner®
Burn CDs with optimum quality
Fox Audio CD Burner allows you to create high-quality CDs that can be played in any player. It supports all popular CD burners and all sizes of CDs DAO and TAO burning modes for all disc types. The CD Burner features an easy-to-use interface specially designed to burn CD, which helps you to catch on to the system quickly. New user or experienced user can finish his burning task with few clicks. Just use Fox Audio CD Burner to burn custom high-quality CDs from your favorite MP3s and play them back in your car, home stereo or portable CD player.
Fox Audio CD Burner cho phép bạn tạo ra những CD với chất lượng tuyệt vời.
Fox® Audio Converter®
Powerful Audio Conversion
Fox Audio Converter is a useful audio conversion application. It allows you to convert audio files from one format to another, as well as convert to the same format with different audio-encoding parameters (such as resembling and bit rate). With predefined output qualities, you can quickly set and manage the parameters for conversion. Also, you easily can convert multiple audio files at one time with batch conversion. With a clear and intuitive interface, you can catch on to the system quickly. It supports a wide range of audio formats such as MP3/MP2,WMA,WAV,OGG,MPC,VOX,RAW,G723,G726. These features meet all your needs for audio converting, try it now!
Fox Audio Converter là một tiện ích cho việc chuyển đổi âm thanh
Fox® Audio Recorder®
Professional Audio recording software
Fox Audio Recorder helps you to transfer tapes, LPs, live performances, Internet radio, TV, DVD player, or any other sound source to your hard drive with no loss of quality. Various effective recording settings make your recording task interesting and attractive.
The software helps to protect your valuable recordings--just set the sound source, the recording quality, and volume, then start recording.
Fox Audio Recorder giúp bạn chuyển apes, LPs, live performances, Internet radio, TV, DVD player hay bất cức nguồn âm thanh nào về ổ cứng của bạn mà ko giảm chất lượng.
Fox® DVD Ripper Pro®
Easy to use and the fastest DVD rip software
Fox DVD Ripper Pro is professional software designed to convert your favorite DVD movies to popular video formats including AVI, MPEG1, MEEG2, WAV, 3GP, iPod, PSP video files format. The powerful tool offers the best picture quality but the converted file only takes up 10% of the original file size.
Fox DVD Ripper Pro là một phần mềm chuyên nghiệp được thiết kế để biên tập những DVD movies bạn thích sang các định dạng thông dụng như AVI MPEG1, MPeG2,WAV... Một công cụ mạnh với chất lượng hình ảnh tốt nhất nhưng dung lượng file sau khi biên tập chỉ bằng 10% file cũ.
Fox DVD Ripper Pro provides a simple, fast method to rip DVD. No more multiple programs, no more complex progress, as easy as 1-2-3! Just a few clicks, you can choose subtitle, audio track, and customize output video and audio quality.
With the latest encoding technology, both the output quality and ripping speed are unbeatable.
Fox DVD Ripper Pro
rất nhỏ gọn đơn giản, dễ dàng như đếm 1 2 3. Chỉ cần vài cái nhấp chuột là bạn có thể chọn sub, âm tranh và định dạng video , chất lượng âm thanh.
:39:
Fox® Flash Decompiler®
Professional Flash decompiler software
Fox Flash Decompiler Convert SWF to EXE in seconds! Fox Flash Decompiler is the only application that is capable of converting SWF to EXE with high speed and high quality. With Fox Flash Decompiler you can turn any of your SWF movies into their source EXE format. SWF to EXE converting has never been easier!
Fox Flash Decompile not only allows you to export all elements of any flash file, but also allows you to export data to rebuild FLA file.
Fox® Video Capture®
Powerful video capture software
Fox Video Capture is a simple, easy to use video recorder that allows you to capture video directly from a webcam (video camera), DV or any analog video source. You can set video compression codec and audio compression codec, output frame size and frame rate. You can also set properties of each capture device, preview and record real-time video, watch TV (TV Tuner is installed).
Download 37.7mb
D-Link :113:
[hide]
[/hide]
