Audio Edit Magic 9.2.20 is a visual audio editor and recorder software solution, which supports many advanced and powerful operations with audio data.
With Audio Edit Magic you can:
• Open, create, and save audio files in any of the supported formats (can also save any portion of a loaded file to disk as a new file);
• Display audio data waveform (Zoom Full, Zoom In, Zoom Out, Zoom Vertical);
• Play audio files or any portion of the files (Play, Pause, Stop);
• Record audio data from a microphone or any other available input device;
• Edit audio files visually (Cut, Copy, Delete Selection, Delete Silence, Paste, Paste From File, Mix, Mix From File);
• Apply various effects (Amplify, Compressor, Delay, Equalize, Fade In and Fade Out, Flanger, Invert, Normalize, Phaser, Reverb, Reverse, Silence, Shrink, Stretch, Vibrato, etc.);
• Apply different filters to any selected portion of audio files;
• Supports all major audio file formats such as uncompressed WAV; compressed WAV; MP3, MP2; Ogg; WMA; CDA (Audio CD Tracks); AVI; AIFF; AU; G.721, G.723, G.726; VOX; RAW.
• And much more!
Code:Audio Edit Magic 9.2.20
- XP Codec Pack 2.4.1
- Media Player Classic HomeCinema 1.5.2.3022 (x86/x64)(+Portable) - Giải trí đa phương tiện
- [D-Link]x264 Video Codec r906
- Winamp 5.581 Build 2985
- Plugin cho Google Chrome
- J.River Media Center 15.0.142
- Cakewalk Pyro Audio Creator v1.5.2 (Serial & RegKey)
- E-Soft DJ.Studio Pro 4.2.2.7.4 Công Cụ DJ Nhạc của các nhạc công
- J. River Media Center 14.0.50
- [MF] MediaMonkey Gold v3.0.3.1183 Final - trình chơi media đa năng
