Antenna Web Design Studio v3.5.498 | 7.3 Mb
Antenna lets you to design and develop great looking professional web sites rapidly without any coding or HTML knowledge. Antenna enables you to make great looking web sites rapidly. Create a professional web site to promote yourself or your company. Publish your site online or distribute on CD as an interactive CV. Be seen - make a good impression - get noticed!
You can create your own web pages and digital photo galleries in minutes, without any HTML knowledge. Antenna's powerful editor is entirely visual, and pixel accurate - putting you in control. Wherever you drag & drop text, pictures, buttons, flash animation and movies on the page, that's exactly where they will appear in the web browser.
When you are ready to publish your site, you won't need to buy any additional software - Antenna has its own publisher built in, and it can be set to publish changes only, so you can update your site very quickly.
You can also create smooth gradient backgrounds and attractive glossy buttons without switching between applications - it's all built in! Give yourself a competitive edge and dip your toes into the international scene at any time - make any part of your web site multilingual. And if you need a hand there's a set of free online tutorials and expert tips, a comprehensive 100 page fully illustrated colour User Guide and free technical support.
Here are some key features of "Antenna - Web Design Studio":
Visual editor for Rapid Site Development:
· Drag and drop WYSIWYG - Pixel Accurate. Position items exactly where you want them to be. Customisable 'snap-to-grid' facility for easy object alignment.
Powerful Graphics Capabilities built in:
· Make professional web galleries of your digital photos with the Photo Gallery creator. Create high-quality button graphics and gradients with Antenna's integrated Button and Gradient Lab utilities - all built in, no extra software required.
Full Layers System with Layer Transparency:
· You can build your web pages in layers, place related items on the same layer, add new layers, overlap items and change layer opacity for translucent effects.
Include Pages:
· Include any page as a layer on any other page. A real time saver when you need the same items to appear on many pages - and any changes are reflected instantly across all other pages!
Design with Style - CSS Styles Editor built in:
· Perfect your look, and make sweeping visual changes across the whole site quickly and simply.
Rollover Buttons and Special FX:
· Shadows, motion blur, neon, water - all done visually, no HTML coding required.
Add Audio and Video to your web pages:
· Supports AVI, MPEG, QuickTime and Flash.
Object Properties Palette:
· No need for complex modal dialog boxes - modify items using a floating palette and see the results instantly. Very quick - once you know how to customise one type of object, you know how to customise them all.
Single File Project:
· A website is saved as a single file on disk - very easy to manage. Organise your web and move files around at any time without having to worry about broken links - Antenna keeps links updated automatically.
Integrated FTP Publisher:
· No need for additional publishing software. Antenna's built in publisher includes a 'Publish Changes Only' option for rapid site updates.
Multiple Languages - Site Localisation:
· All text and image objects support the facility to change their content based on language - so you can easily create and maintain multilingual sites from a single design.
Custom HTML:
· Advanced users can add custom HTML code and javascript, and even create completely new object types using Antenna's HTML plugin system.
Homepage - http://www.stormdance.net/
