1CLICK DVD COPY PRO v 4.0.9.0 | 5,48 MB
1CLICK DVD COPY - PRO™ is a fast, easy-to-use, full featured software for copying DVD movies onto DVD discs. The latest version now incorporates CPRx™ technology to ensure the highest level of success copying the latest generation of DVD movies.
You now have complete control over the final copy. Use the Copy Presets™ or the more advanced features to select what content will be copied and how much compression will be used. With 1CLICK DVD COPY - PRO, you can make a perfect copy with just one click.
* Windows Vista Compatible
* CPRx™ technology for copying new DVD movies.
* Copy Presets™ - One click preset for each type of DVD copy.
* Preview the movie, extras and menus.
* Include or exclude movie and menus based on preview.
* Select individual audio, video, and subtitles streams.
* Control the amount of video compression used.
* Make additional backup copies without re-copying the DVD.
* Copy Episodic DVD Movies, TV Series, etc.
* Copy a movie to your hard drive - great for laptops.
* Supports copying of Multi-Channel Audio (Dolby Digital 5.1, DTS).
* Supports both NTSC and PAL DVD movies.
* Supports Dual Layer media.
* Free software updates for a year.
* Free technical support.
System Requirements
* Windows Vista, XP, 2000, Me or 98SE
* 500 MHz Intel® Pentium III process or equivalent with 256MB of RAM
* Up to 9 GB available hard disc space for DVD images and temporary DVD files
* DVD reader (DVD writer required for burning DVDs)
