1CLICK DVD Copy Pro 4.2.4.0 Final | 6.11 MB
1Click DVD Copy Pro includes enhanced features that provide you with greater control over the DVD burning process. Like 1Click DVD Copy, this Pro version has all the key features you need to copy any DVD movie including: CPRx enhanced copy protection removal technology, auto compression, episodic DVD support, Dual Layer support and CSS decryption support.
CPRx is a unique and innovative solution to copy new DVD movies which contain bad sectors or bad DVD structure. Many popular DVD movies are now created in such a way as to make it difficult for backup software to copy them properly. This can result in errors during the copy process, or bad playback after the copy is completed.
Features of 1Click DVD Copy Pro 4.2:
- CPRx technology for copying new DVD movies.
- Copy Presets™ - One click preset for each type of DVD copy.
- Preview the movie, extras and menus.
- Include or exclude movie and menus based on preview.
- Select individual audio, video, and subtitles streams.
- Control the amount of video compression used.
- Make additional backup copies without re-copying the DVD.
- Copy Episodic DVD Movies, TV Series, etc.
- Copy a movie to your hard drive - great for laptops.
- Supports copying of Multi-Channel Audio (Dolby Digital 5.1, DTS).
- Supports both NTSC and PAL DVD movies.
- Supports Dual Layer media.
- Multilingual support (English, French, Serbian, Spanish).
Changes in 1Click DVD Copy Pro 4.2.4.0 (Dec 27, 2010):
- Updated: CPRx update for movies like “Search for Santa Paws”
Homepage - http://www.lgsoftwareinnovations.com/
Download From HotFile
http://hotfile.com/dl/92724318/7b56b...2.4.0.rar.html
Download From FileServe
http://www.fileserve.com/file/x2eByQj
Download From FileSonic
http://www.filesonic.com/file/490990...dcp4.2.4.0.rar
- Joboshare DVD Toolkit Platinum 2.3.7.0508
- AnyDVD & AnyDVD HD 6.5.5.5 Final
- PowerISO v4.6
- DAEMON Tools Pro v4.10.218.0 - Advanced FULL
- Alcohol 120% 1.9.8.7507 - Tạo đĩa ảo,chép,burn,ISO...
- GameJackal Pro 4.0.0.3 Beta
- IsoBuster Pro 2.5.0.0
- Magic ISO Maker v5.5.261 - tạo và biên tập file ISO
- AoA DVD Ripper 5.1.9.1208
- AnyDVD & AnyDVD HD 6.4.9.2
